Paul Proefrock - Hurricane HM2023 - Lizstick Red
Highly modified Gen. II Hurricane Motorsports build. Engine compartment, hood, firewall, & foot boxes replicate original vehicles.
More Details
Working with Hurricane Motorsports, I designed and converted a S550 Mustang IRS to fit the Hurricane chassis and to accept 15" pin drive wheels. This car is the prototype of their current production. Once I got the body home, I then went to work modifying the cockpit, firewall, footboxes and engine compartment to replicate a 1965 Shelby. The hood has a replica tube frame with skin, radiator tank and shroud copy the 65's. The rim of the cockpit was rolled to replicate the 3/4" tube frame of the AC body. The Hurricane tunnel was removed and replaced with an aluminum tunnel (ala ERA) and copies the interior of the AC.
Hurricane
Front Suspension
Front
Rear Suspension
Rear
Brakes
Yes.
Color Details
Saleen Lizstick Red
Hurricane Motorsports, Mustang II based geometry, QA1 Balljoints, Wilwood ProSpindles, Wilwood brakes, swaybar
2105 S550 Mustang IRS based. Uses the Differential, uprights and wheel bearings. Porsche 930 half shafts with The Driveshaft Shop adapters
Wilwood four piston, front & rearWheels & Tires, Pin Drive Vintage Wheel, Cooper Cobra 235R60/15 front, 295R50/15 rear
Color: Saleen LizStick Red w/ darker ghost stripe
468 Cu. In.
Ford FE - Shelby Aluminum Block
Borla EightStack - Performance Electronics ECU
Valve Train Details
Harlan Sharp Roller, Custom Hydraulic Roller Cam
Ignition
Exhaust
Slipfit Headers - Ceramic Sidepipes
Transmission
Liberty Gears Modified TKO600 w/ Pro5.0 shifter
S550 Mustang IRS
Interior Details
Interior Details
Brunello Leather on Black. Black Wilton Wool carpet. Alum dash w/ rolled edges for steering shaft and glovebox.
Gauges
Smiths
Special Features
Special attention to Hood frame and skin detail to replicate original car
  • Like
Reactions: RobReed18
Roadsters
PaulProe
Manchester, MO 63021
More in Roadsters
